Hey,
Encoded this file from TV using PicVideo JPEG codec at 18, using filters "blur more". Record as PAL 352x288. After that used TMPG to encode using VCD PAL template.
System specs-
P3 - 450
256mb SDRAM
40gig 5400RPM HDD
Leadtek WinFast TV 2000 tuner.
Please copy and paste this link and download the capture-test.mpg file and then give me some feedbackthanks.
http://www.geocities.com/cybermage23/
I think its not bad.. I was previously using Huffuyv but the quality between Huffuyv and PicVideo isnt very much and Huffuyv is so much bigger heh.
I saw your little sample. I think it's really good, but just a little short and not a lot of motion.
looks OK, but I believe you still have some interlace problems in the picture. If you are capturing PAL, then you are better off disguarding one of the fields for VCD, as they represent a different temporal point. deinterlacing can help, although I find I get better quality to seperate the fields (this conversion turns video into 50fps with half original height), do temporal noise reduction followed by halving the frame rate, resize to VCD.
Jim
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
thanks.
