I just installed SVCD2DVD full 2.1 version installation went ok but when i try to run the program i get this error message.
and when i click ok gives me this
I have up to date with windows updates running Windows XP ProCode:Version: SVCD2DVD 2.1 Build: 2.1.2474.30185 Type: System.ArithmeticException Source: System.Drawing Message: Overflow or underflow in the arithmetic operation. InnerException: StackTrace: at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont) at System.Drawing.Font.Initialize(String familyName, Single emSize, FontStyle style, GraphicsUnit unit) at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit) at x3284ccece41ee22b.x210ff09a2516b1a7.x85601834555fb7d5() at x3284ccece41ee22b.x210ff09a2516b1a7..ctor() at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322395(String[] xce8d8c7e3c2c2426)
please if anyone can help me.
thanks
Results 1 to 9 of 9
A SEARCH on the error show this:
https://forum.videohelp.com/viewtopic.php?p=1279399#1279399
You might give that a shot.Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Dwight
- Herm Albright
That does not have the same message as mine
here this one is mine
and this one is his
Message: Font 'Tahoma' doesn't support style 'Regular'.
they both have deferent problem i find. -
The first link I posted has the exact same error message you posted. Did you try a reinstall of SVCD2DVD after fixing your .NET installation?
Dwight
- Herm Albright
Both cited posts are relevant. But also have you had it working before on this PC or is this the first time you have installed it?
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 14:44 -
Error on Startup SVCD2DVD 2.5
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 05:05 -
Error reports in SVCD2DVD
By deoldeprinter in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th Nov 2007, 22:03 -
svcd2dvd error urgent request
By dvds2u in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 10th May 2007, 10:22
