hello,
i have a long video in divx format (avi), and i would like to create checkpoints, so whenever i open it again, i can just jump to a certain point in the video. it would be even better if i can write the checkpoint's name.
i'm using media player classic
is there a way to do it? if so, how?
thanks
tom
If you use the latest divx 6 codec and their encoder tool, you should be able to set chapter points. Check out divx.com
Google is your Friend -
Originally Posted by tomchook
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10 -
DV-AVI zu Divx file in 16:9
By sepp 123 in forum Video ConversionReplies: 1Last Post: 12th Oct 2008, 08:35 -
DVD to: Image file vs. DivX (AVI)
By mpalm887 in forum DVD RippingReplies: 4Last Post: 28th Oct 2007, 22:54 -
Reducing AVI/DivX file sizes
By webstar in forum ffmpegX general discussionReplies: 5Last Post: 17th Jul 2007, 09:52 -
Need to join a avi and divx file, not sure how
By MattP2007 in forum Newbie / General discussionsReplies: 5Last Post: 25th May 2007, 10:24
