I just bought the new Sony DCR DVD 505. It burns onto a mini DVD.
Question: How do I edit what movie I shot? Is there a software for this? Is there a way to put two or three miniDVDs of movies on one DVD? How do I get a regular DVD menu with chapters, titles. etc.
Thanks for reading this,
bryan kendall
Assuming it's in DVD format, you could use VOB2MPG to convert them to MPEG files, then just use a MPEG editor like VideoReDo or MPEG-VCR or similar. Then when you have it all the way you want it, convert it to DVD format with a authoring program like TMPGEnc DVD Author or for freeware, DVDAuthorgui or GUI for dvdauthor. The authoring program does the chapters and menus.
Regarding converting to MPEG - the camera comes with (should have come with) a program called Picture Package DVD Viewer. When you finalize the disc and put it in your PC (or you can just connect the camera) DVD Viewer will show you the individual MPEGs. Then you can select them all, hit Copy to Hard Disk, and you will have the MPEGs on the PC. Then you can do the editing (I use MPEG-VCR) and authoring.
As for putting three discs on one - camcorderinfo.com has a sticky:
http://www.camcorderinfo.com/bbs/t122189.html
Good Luck!XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card
Know Nothing Newbie. Edit Sony DCR-TRV27 video and upload to youtube.
By CJ-8 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2011, 18:26 -
mini DVD recorded by SONY DCR-DVD203 unreadable at DVD ROM of PC
By knightatarms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Dec 2010, 11:02 -
Editing Sony DCR DVD 405 Recording/Files in Windows Moviemaker and iMovie
By pmblr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 27th Nov 2010, 15:19 -
Which is good programme to create dvd from sony handycam dcr-sx43?
By jactor in forum Authoring (DVD)Replies: 0Last Post: 19th May 2010, 17:46 -
sony dcr-dvd108 - No files appear when mindi-DVD inserted in PC
By todd72173 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Oct 2009, 20:18
