I'm tryng to convert a downloaded divx whch plays excellent on my pc but as soon as i click start on TMPGEnc it shows the following message error:"an error occured when audio is decoded" Is there anyway i can solve this audio problem? If Iignore the error and go forth encoding the vcd turns out without audio!
Hi...
you must extract the audio with virtualdub...
the filesize can be really big... but once you start to encode it with tmpgenc, it will reduce a little bit..
when this is done you start TMPGenc again and load the avi file, and the .wav file..... SEPERATLY!!!!
than do it again.....
as long as my boss thinks i make a lot of money, i will pretend to work hard ;) -
It works!!!!! thanks a lot Toolman!!! I chose direct audio stream for the audio in virtualdub and the WAV fle came out less than 100MB! I thought much worst!!
ciao
Luca -
you're welcom....
I can't seem to load any file without getting the dreaded "an error occurred when audio is decoded. I used virtaul dub and created a .wav file but it is out of sync with the video. Please help.
I found my own fix. This multiplex business was very complicated. So, I found another little program called avi2vcd. It comes with a decompression program which I used. It creates a whole new file with the video. I then went back to TMPGEnc and began to encode it to MPEG. I just tested it and the audio is now in sync with the video.
AVCHD - Converting video pass 1: Errorcode: 0x0401,Error occured
By time2innov8 in forum Authoring (Blu-ray)Replies: 10Last Post: 19th Jan 2014, 15:20 -
Error -1856: An Unknown error occured
By Tyler2000 in forum Software PlayingReplies: 2Last Post: 27th Oct 2010, 20:55 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 14:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
unsupported audio type error message in AutoGK
By ham2405 in forum AudioReplies: 2Last Post: 26th Dec 2007, 17:53
