Does anyone have experience converting MPEG2 to H.264 with an ATI Avivo graphics card?
Yes, it was a while ago. The results were crap.
http://www.anandtech.com/show/2685
http://www.anandtech.com/show/1794
http://www.anandtech.com/show/2586 -
If all you are looking to do is make somthing to play on a hand held media player, the Avivo converter could work for you. For anything else, as jagabo stated, the quality sucks. The only output setting availabe is a low to high quality slider that sets the bit rate and video size. It has only one h.264 output format, which is the ipod setting. The only saving grace to the app. is its speed. For a five minute cut of a DVD rip to the low ipod output setting, I was getting about 235 fps. So, even on an older single core PC you could obtain a livable output rate.
edit:
Depending on the ATI video adapter, there also may be h.264 HD 720p and 1080p codecs available to you. Avivo for my older X1650 pro card does not show these.Last edited by JimmyS; 24th Jun 2010 at 13:45.
Problems converting H.264 AVC to MPEG2
By Gwar in forum Video ConversionReplies: 8Last Post: 4th Jul 2011, 12:29 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 09:12 -
MPEG2 files of VOB2MPG not accepted by ATI AVIVO video converter
By 33M344 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th May 2010, 14:53 -
Why does Avivo encoder fail to transcode a H.264 vid?
By jones24 in forum Newbie / General discussionsReplies: 0Last Post: 16th Aug 2009, 06:01 -
ATI AVIVO
By therock003 in forum Capturing and VCRReplies: 18Last Post: 28th Jan 2009, 19:31
