I have been using the card without any problems for TV and recording but I connected the AV Input to record a VHS tape and I have not been able to get any of the programs to recognizine it as a source. I am using the Cyberlink Director and Producer software that came with it. I realize there might be better software but it should at least recognize the card right? I downloaded the latest drivers from ATI and the ATI Unified AVStream Driver is listed under Sound, Video, and Game Controllers. Any help would be appreciated.
Try using the Windows Movie Maker program (it should already be on your computer if you use Windows XP). It can capture video from a capture device using the "Capture Video" in the "Movie Tasks". As a minimum, this should see the 550 card and allow you to select the 550's composite or svideo input to be the input source for the capture. Using this might give you insights on using the Cyberlink software. Be aware that some capture apps capture using an AVI file format, bypassing the 550's hardware MPEG2 encoder.
Usually long gone and forgotten
ATI Theatre Pro 550
By didikai in forum Capturing and VCRReplies: 2Last Post: 27th Feb 2012, 11:15 -
Hardware MPEG-2 Capture Software ATI Theater 550 Pro
By CaZeek in forum Capturing and VCRReplies: 9Last Post: 22nd Nov 2010, 11:57 -
Theater Pro 550
By Jenkjunk in forum Capturing and VCRReplies: 4Last Post: 12th Oct 2009, 21:48 -
Mainstream S/W to take full advantage of ATI 550 PRO H/W encoding
By inspiron2 in forum Capturing and VCRReplies: 2Last Post: 6th Jul 2008, 17:24 -
Ati 550 pro best capture software...
By RE*S.T.A.R.S.*2 in forum Capturing and VCRReplies: 13Last Post: 14th Jun 2007, 17:46
