helo, u guys must help me out, please..
here is the situation,
i wanted to burn 700mb avi into a dvd using avi2dvd,
at encoder setting, i pick HCEnc ,
profile : best
matrix : mpeg
after hours of encoding, the ISO is created..
everything looks fine until the movie played,
i put english subtitle (only 2 options> off, and english)
when i choose the subtitle english, this what happens:
the subtitle is sync with the movie, it appeared right when it should be,
but not all the subtitles,
EX:
A says : hi
B says : hi there
C says : im encoding a movie
D says : me too
E says : i'm using avi2DVD
F says : yeah, we all use it
subtitle A will appear, B will not, and then C appeared, D appeared, E appeared, F not
i'm not sure if it has some patterns but the point is some subtitle is missing,
this is what i put on my subtitle setting
subtitle format : *.TXT (DVD SUBTITLE SYSTEM), can't put *.srt coz it will not sync
character set : ISO8859-15
language : english
font face : arial.ttf
font size : 24
>i also have the ntsc to pal conversion box checked<
>aspect ratio is 16/9<
now, the second problem is with the ISO size, at the output i picked DVD5 (4.7 GB)
but the image file that it created is 4.9 GB, when i tried to burn them, of coz the space is not enough so i can't burn em.
The video quality is superb, and the menu is generated perfectly,but theres only 2 problems
1. the subtitle
2. the size of the image file
should i use different encoder settings, and how do i correct the subtitle problem?
i wanted the result to be DVD quality movie with all the space in the DVD used, not like only 1-2gb of an image size, that would be a waste.
so, im beggin y'all, please help meeee.....![]()
hmm.. i'm using PAL tv, is it okay if i didn't check the ntsc to pal conversion box?
how to know whether the original avi file is NTSC or PAL?
oh, i just hope it will solve the subtitle problem, its driving me crazy coz i've spent days working on this thing...
problems with avi2dvd
By kayla33 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2011, 14:12 -
Avi2dvd menu problems
By bman321 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2009, 20:18 -
avi2dvd sound problems
By justmenow55 in forum Video ConversionReplies: 5Last Post: 13th Aug 2007, 03:58 -
By justmenow55 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 12:50 -
Avi2DVD
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2007, 14:53
