Hi, I have convert a film from avi(div_x) to mpg because I want to burn it to a VCD. But the mpg file is to big (900Mb). Is it possible to reduce it to 800Mb?
Please help me!
I have already cut some of the text in the end.
you could cut out some of the film. (ie credits)
or cut the MPEG in half, and use 2 CD-R's
he there....
you have 2 options:
1.. you have to resize the bitrate.. you can do this in TMPGenc, the downside of this is that the quality is a little bit bad...
2. Leave the end and the beginning and burn it on 2 cd's..
you can use TMPGenc also to cut it in to 2 peaces..
as long as my boss thinks i make a lot of money, i will pretend to work hard ;) -
Thank u Toolman
Can you give me some instructions how to resize the birate?
Please -
try this:
1) start TMPGenc..
2) go to settings
3) go to video.....
4) change @ option "bitrate" from 1150... to 1000...
I have never done this before, so i cant tell you what the quality will be when you're done... but it seems to work.. so give it a try.
I usually just put the film on 2 cd's, it isn't handy, but i see it like going to the theater, you also get a break there
good luck
do you know something about subtitles.... ive got a post "subtitles...." maybe you can answer it 4 me...
Thanks for the tip Toolman.
I will try it but the problem is that it takes 6 hours to convert it to 1000
My computer very slow I think...
I don't know anything about subtitles.
I'm a "Newbie"!! Sorry
My First Big Project to film about 20 hours of footage
By Intergage in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2010, 22:18 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 17:14 -
The Independent Film Channel - efficient film challenge - cash prizes
By minidv2dvd in forum Latest Video NewsReplies: 1Last Post: 23rd Oct 2009, 10:44 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
What type of discs do the big film companies use?
By boing in forum Newbie / General discussionsReplies: 19Last Post: 27th Jun 2007, 00:37
