hi
i can not find any program which will allow me to merge(join) 2 mpeg files with ac3 (6channel) without reencoding which are mpegs from my sony dvd-r camcorder dcr-403
tmpgenc dvd author reads those files to be authored but i can can not merge 2 files or i do not know how
thanks for any help
Did you add the files to the same track in TDA and what is the total file size (if less 1024MB, you could use the output VOB from the authored folder)?
Try also TMPGEnc MPEG Editor or VideoReDo. -
can tsmuxer change h.264 mov to m2ts files without reencoding?
By Onceler2 in forum Video ConversionReplies: 2Last Post: 20th Mar 2012, 05:47 -
Cut HD files (h264/avc) without reencoding
By cd090580 in forum EditingReplies: 3Last Post: 25th Jun 2010, 19:37 -
is it possible to author a BR usig m2ts files without reencoding?
By Onceler2 in forum Authoring (Blu-ray)Replies: 6Last Post: 5th May 2010, 11:23 -
How can i creade a Dvd video from camera files w/o reencoding them?
By junglemike in forum Authoring (DVD)Replies: 6Last Post: 7th Apr 2009, 20:41 -
How to backup multiple AVCHD files to BD-format DVDr without reencoding
By jodal in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Dec 2008, 16:45
