Hi All.
I am making a dvd with a menu from dvd lab. I have 4 episodes of a series on a disc, and want to run it through this program, make a menu, then shrink by using dvd shrink and then burn.
Now i imported my VOB files into DVD lab, set chapter points manually (it wouldn't recognize the previous chapter points), made a menu etc, and compiled thr DVD onto my hard disk.
Everything works great, apart from the subtitles. Before DVD-LAb, they were normal subtitles, white, and now, they are red and blue lol. its like they are blue, with a red "outline". I have tried this twice and both times i came up with the same result, which is colored subtitles instead of white!!
I'd really appreciate any help anyone can give.
Thanks, and Merry Xmas to all of you
AK
I never use VOBs in DVD Lab Pro out of choice, and would never try to get it to use subtitles from within VOBs. On the very few occasions I have had to use VOBS I have always demuxed them. I am guessing you have never done anything like that.
I suspect that if you go into the built-in subtitle editor you will not see subtitles available for editing, so you will probably have to adjust the colours using a third party program after compiling with DVD Lab. I would try DVDSubEdit.Read my blog here.
guns1inger Thanks a million! I used Dvdsubedit and that program is simply awesome, very simple and easy to use!! i changed a lot from there like the colour of the subtitles and the position on the screen.
Appreciate it!
Merry Xmas
AK
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 11:57 -
NTSC issue in DVD-Lab pro
By Ankin in forum SubtitleReplies: 2Last Post: 20th Aug 2010, 16:19 -
dvd-lab issue, needs to be solved desperately
By cL0N31 in forum Newbie / General discussionsReplies: 8Last Post: 28th Nov 2007, 11:49 -
DVD Lab Pro - 2 cells issue
By GangstaRap in forum Authoring (DVD)Replies: 4Last Post: 24th May 2007, 10:44
