I downloaded a AVI-file which was encoded with h264. I view the file with VLC and now I want to put it on a DVD, but uptil now all the conversions failed.
Can anyone help me.
What failed? No output file/unsatisfied with output file? Burn failure? DVD not accepted by player?
Also some more info on your source file would be helpful. What is the duration of your file (minutes)? What is the frame size in pixels? What is the aspect ratio (2.35:1/16:9/4:3)? What is the framerate (23.976/29.97/25 fps)? What is the audio format (mp3/aac/ac3, etc)? What is the audio bitrate?
Thanks for replying.
Codec H264
resolution 576x720, framerate 25.000, sample rate 22050 Hz, Bit rate 38 kb/s.
The file can be downloaded from: http://www.nkbv.nl/wedstrijden/nederlands%20team/wedstrijdvideos/3609.html
(F Jorg Verhoeven)
I could convert it with VisualHub, but the width size is now to big.
Can I alter it so that it can put it on DVD and see it on television?
Your DVD may end up like this, because the source file is more tall than wide, unlike a tv set.
Rename your source file by removing spaces in the filename, just to avoid some possible errors. Load your source file into ffmpegX. Select the DVD ffmpeg preset. In the video tab, set the video size to 400x576 to avoid a stretched picture. In the audio tab, you may lower the bitrate and channels, as your source file isn't exactly hifi. In the Filters tab, set Letterbox to [0,0,160,160] to get black bars on the sides. In the Options tab, turn on HQ, B-frames, 4MV and Trellis for more quality per MB. Encode.
Eureka!!
At first ffmpegX was finished just after a few seconds. But finally it worked. Thanks a lot.
What form of h264 will VideoRedo h264 tvsuite accept?
By Asterra in forum Video ConversionReplies: 4Last Post: 12th Apr 2012, 14:22 -
H264 to DVD in ffmpegX
By cb678 in forum ffmpegX general discussionReplies: 1Last Post: 19th Nov 2011, 16:36 -
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 15:13 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 02:20
