i have a few project files (.veg) that i need to make into one movie (think one project for intro, one middle, one credits project)
is there anyway i can combine each project to make one project without rendering each into separate avi's?
thanks for the info...
but i tried doing what you said, and when i dragged the .veg file from the explorer into the timeline, it worked great... however, when i tried to drag another .veg after the one i already put in the timeline, it simply replaced the one that was there. it wont let me add one after the other.
am i missing something?
and i am using vegas 5.0.
thanks -
I know about the nested projects feature but I just don't use it. Instead, I work on pieces of the project and then render them out in their own ideos. Later I put them together into one render project. The downside is that much more project planning is required and slight video and audio quality is lost (around 3%) when rerendering files.
Programs I Frequently Use:
Sony Vegas 7
Autodesk 3ds Max 9
Camtasia Studio 4 -
Don't know where you can up with the 3% from, but there are plenty of ways to do it without losing any quality. The number of lossless codecs available seems to be growing by the week.
I like using nested projects for common and frequently used items like credits and overlays that also may need a simple change like a name added or altered. It is simpler to do this in a project, then drop this into another project, than to lose time rendering intermediate files.Read my blog here.
Combining multiple titles into one
By augerpro in forum Video ConversionReplies: 2Last Post: 22nd Sep 2011, 16:50 -
Any Places for Vegas Projects aka Veggies online?
By inmanproduction in forum Newbie / General discussionsReplies: 6Last Post: 14th Sep 2011, 12:27 -
A question about loading time of Vegas projects
By Morten in forum EditingReplies: 0Last Post: 18th Aug 2009, 03:53 -
Vegas Movie Studio Platinum 9.0 saves projects wrong!!!
By TonKhaO in forum EditingReplies: 0Last Post: 12th Apr 2009, 07:59 -
Batch processing of multiple projects...
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Sep 2008, 07:31
