Hey people, I am sure this has been asked, but what is the best way to go from a .tp file to a playable dvd? Please read on,
I tried videoredo with good luck, and seems to pretty much just what I want, but my trial has run out, so basically my question is, should I spend the $50 on the program or is there a better option?
This is what I am doing,
Using videoredo to cut the unwanted stuff from my capture, commercials etc. then saving as a.vob or a mpeg file. Then I use ultra dvd creator to convert this file to a dvd file and then burn.
Is there a better way, or am I better off just buying the videoredo and doing what I have been?
Thanks much,
Brew
Results 1 to 1 of 1
