Hello,
In Canada:
I can't seem to find a widescreen lcd computer monitor 20-22 inch that has pal support for the inputs (composite / component / dvi) i want to be able to play pal & ntsc dvd thru the inputs (svideo / component). It also has to be an lcd monitor that has hdcp dvi for when i upgrade the computer with blu ray
any ideas??
i have been looking at samsung 215tw but most models seem to be ntsc only for the inputs
I have a couple of devices that will be playing ntsc & pal discs through the inputs
and have a number of pal dvds
- Thanks
Kevin
	Computer monitors rarely support video inputs. If they do it is NTSC or PAL not both. These are add on capability to allow the computer monitor to be switched to a low quality TV mode, say for a dorm or kids room. You might be able to order a PAL model from Europe, but it will never work for HD/BD DVD.
 http://compreviews.about.com/od/general/a/HDParadox.htm
  Dualboot and LCD monitor Question?By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 03:53
  lcd hdtv or computer monitor for best picture?By teevee in forum Newbie / General discussionsReplies: 9Last Post: 14th Feb 2008, 15:32
  pal/ntsc lcd monitor questionBy scotstrength in forum Media Center PC / MediaCentersReplies: 0Last Post: 30th Oct 2007, 13:17
  LCD PC FP WS monitor questionBy majax79 in forum ComputerReplies: 1Last Post: 15th Oct 2007, 10:15
  LCD Monitor QuestionBy jollyjohn in forum ComputerReplies: 2Last Post: 21st Jul 2007, 06:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
