can u use dvd shrink to compress mutilple mpegs to be burned to dvds? if not what program can i use to compress these files to fit on dvd.
I am not fully certain of this but I think that DVDShrink will just do it's thing on a DVD folder. You have a couple choices. Re-encode the mpegs to the proper size to begin with (preferably from your source files) or use a program such as SVCD2DVD to make a DVD using your mpeg files then shrink it with DVDShrink. Actually you have another option, spread your mpegs over a couple DVD's and avoid the shrinkage altogether. SVCD2DVD will not re-encode your mpeg files if they are the right aspect ratio for brand of DVD (NTSC or PAL).
Mark
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
