I'm trying to connect my Dell Inspiron, Win XP laptop to our new Sony Bravia LCD TV via a 15pin serial cable that came with the TV. I connect it and go to PC input mode on the TV and it recognises no source. Is there a way on the laptop to output to the serial? Thanks for any help.
Originally Posted by hhhgamewmx7
Read the computer manual for setting up for dual monitor. First monitor is the laptop LCD. Second will usually be the S-Video or VGA out. Set the VGA out for a resolution the TV's manual says it will accept. 1024x768 is probably a good first choice. Refresh needs to be 60Hz. Then try 1280x768 or 1366x768. -
Also, you may need to toggle which display the video is sent to using the function keys.
Nothing can stop me now, 'cause I don't care anymore. -
Originally Posted by ViRaL1
Small Notebook with Firewire Connectivity
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2009, 13:56 -
Looking for something like the WD HD, but would like net work connectivity
By Jhon in forum Media Center PC / MediaCentersReplies: 7Last Post: 18th Apr 2009, 08:05 -
Troubleshooting DV camcorder connectivity
By JohnnyMalaria in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Mar 2008, 02:25 -
Internet Connectivity Problems
By RKelly in forum ComputerReplies: 4Last Post: 19th Feb 2008, 11:28 -
usb connectivity in DVD Rec
By nirbhayn in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2007, 18:30
