  1. Hello all,
    I have a question for everyone. I'm still pretty new to the whole conversion scene. I have a .wmv file that I have on my computer and it has a subtitle imbedded in the file but there are no additional files in the folder containing the video file. If I use WinAVI to conver the file from .wmv to DVD format will that keep the subtitle? And if not, if anyone knows of a good program that I can do this with any suggestions would be great.
    carbfrze
    "Beeflog, beeflog what a treat! A hefty hunk of processed Meat! Dipped in mustard oh what JOY! I'm a jolly Beeflog Boy!!!"
    Apr 2004
    Miskatonic U
    Yes, because the subtitle is part of the video, not a separate entity. The subtitle will always be there, and not something you can switch off. There is no simple way to extract the subtitle to make it switchable.
    I don't suppose I can convince you that WinAVI is a piece of monkey crap and use something better ?
    Read my blog here.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If the subtitles are rendered into the video, sure, it will carry over to your DVD version. If it's a separate multiplexed subtitle stream (does WMV handle that?) like xsubs in the WMV I doubt it will.
    ...and using WinAVI is rarely (if ever) the solution to anything at all.
    But then - it's not more complicated than giving it a try, is it?
    /Mats
    <edit>guns1inger beat me to it... </edit>
