Hi all,
been using canopus to create dvds from avi's, but doesn't have the ability to create menu's. wondering if anyone can help out with a suggestion on how i can add menu's after authoring, or maybe a better solution for me. only wanting to create basic menus.
really appreciate any help or suggestions
thnx
Output elementary streams instead of VOBs, then use GuiforDVAuthor (free) or Tmpgenc DVD Author (not free, but reasonably priced). TDA does effective but simple menus. GFD will do pretty much anything, from simple to complex, so it gives you room to grow or experiment in ways TDA doesn't. And the price is right, so it costs nothing but time to try it out.
Read my blog here.
Add subs to existing authored DVD/Keep original Menus?
By louv68 in forum Authoring (DVD)Replies: 4Last Post: 19th Feb 2012, 18:56 -
Creating DVD menus with DVDAuthor(linux)
By sumit_pankaj in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2009, 11:00 -
Creating a DVD with Menus and switchable subtitles on Mac OS X
By koke_broke in forum MacReplies: 7Last Post: 27th Mar 2009, 12:43 -
Creating DVD Menus
By JARRE2000 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2009, 15:08 -
Authored DVD with GFD, fine on TV, no menus when playing on computer.
By towtruck in forum Authoring (DVD)Replies: 6Last Post: 8th Jun 2007, 17:40
