Hi there, need some help here.
I usually do all my encodings using Premiere Pro/PluginPac Frameserve/TMPGEnc.
I use Premiere just to add fade in and out to the videos.
Now I need to encode a bunch of videos (all MPEG2 at 12Mbps) to fit them all on a DVD.
I didn't try yet, but I'm pretty sure I can't open more than one Premiere and frameserve. Is it possible? (Gonna try when I get home).
Is Premiere able to batch encode all the files? I can leave frameserve and TMPG aside and use Premiere's encoding if it's possible (although I believe I can't select a specific bitrate).
Any better suggestion to encode all the files, adding fade in and out effect, in batch mode?
Thanx.
Results 1 to 1 of 1
Adobe Premiere Pro CS5.5 CUDA encoding slow??
By Brainiac in forum EditingReplies: 5Last Post: 22nd Oct 2011, 23:35 -
Encoding a vob file to use in premiere pro
By spongela in forum Video ConversionReplies: 2Last Post: 17th Oct 2011, 18:31 -
Is there a way to batch convert files in PREMIERE PRO
By mudh in forum EditingReplies: 13Last Post: 12th Oct 2011, 11:23 -
Basic questions on Premiere Pro, Authoring, Encoding...
By nharikrishna in forum Authoring (DVD)Replies: 4Last Post: 11th Oct 2010, 00:49 -
Premiere Pro encoding preset - Can't find it - Pls help!
By slinky005 in forum Video ConversionReplies: 1Last Post: 26th Sep 2008, 13:21
