Sorry if this has been answered somewhere before, but I have searched these forums for hours with no joy.
I have been having audio sync problems with divxs played back on a divx player. They are fine when I play them on my imac G5 10.3.9 in quicktime 7.0.3, but when I burn a few to dvd using toast 7.0.2 and play them back on divx dvd player, the audio goes out of sync. This doesn't happen on all the files, just some of them. I have checked the audio and it is 48,000.
I'm not sure if it's an issue with ffmpegx version w or the binaries for this version, but I don't recall having this problem with previous versions. I have just downloaded verion x, but not installed it yet, plus it uses the same binaries as the previous version, so it might not fix the problem.
Any help would be gratefully appreciated. Cheers
Ive had the same happen with my stand alone dvd player playing divx files etc....usually it starts in snyc with the video then gradually looses sync. I hit pause for a few secs and then play again and it puts it back in sync for some reason. If that doesnt work I fast a few frames then rewind and the sync problem usually fixes itself.
I have a no name brand dvd player that plays anything but sometimes i have to do it 3 or 4 times throughout a movie, which isnt too bigger deal.
Anyway, thats my thoughts!
Happy New year!wilson
MAC'S RULE!
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
