is it possible to do movie only(no menu) in dvd-lab? how?
When you start up DVD Lab or DLP you should get offered a list of project types. One of these is Simple DVD (No Menu). Chose that and it is movie only.
Otherwise, simply delete the menu objects from the tree, drop your video and audio onto the movie object, and on the connections page make sure that both the VMG and First Play objects point at your movie.Read my blog here.
when i open up dvd-lab i don't have the option that you mentioned(is that what they call the wizard?), only a tip. i didn't know per your 2nd option that the menu item can be deleted from the tree, but tried it and it worked. then tried playing with the connections, making sure the VMG and first play object are pointing at the movie. whew!!!!!!..simple, but i'm just clueless....A BIG THANK YOU AGAIN!!!
nothing came up after clicking File then new. the movie1 and connection windows just flikcer as if telling me "hey i'm your new project already". that's okay, i'll just keep a note of what you advised. thanks again.
I just noticed you are using DVD Lab and not DVD Lab Pro. As DVD Lab doesn't support multi-VTS authoring it probably doesn't need to offer the range of choices that DLP does.
Read my blog here.
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
HDTV makes DVD movie look "less" like a movie?
By breakchange in forum DVB / IPTVReplies: 73Last Post: 6th Oct 2011, 09:28 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 01:13 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 11:33
