Yesterday I encoded a small DV (16:9) PAL clip with QUEnc (default QUEnc settings from an Avisynth script). First I made some transitions in Movie Maker (PAL AVI export), and later authored the DVD with GfD.
It all apparently looks fine, but during play (on my standalone) some parts of the video 'lags' a bit (usually a few seconds ahead of transitions, and parts with a lot of shaking), and the transitions are slightly choppy. I know transitions can be a challenge for any MPEG encoder, but I expected better results...
Is there a way to avoid the lagging and the choppiness during transitions?
Is HCenc better in any way for this kind of source? (They are both great encoders!)
Any do's and dont's for this kind of work?
Any suggestions?
Best regards
Bugsy
Transitions, especially cross fades, and scenes of high action need higher bitrate than static scenes. This is independent of encoder used. Your issues sound like classic bitrate starvation.
That said, I believe HCEnc is now a better encoder than QUEnc.
What bitrate settings did you use ? What running time do you have ?Read my blog here.
I didn't notice any lag in VLC, but that doesn't mean they are not there... The transitions doesn't look as professional as I hoped for, but maybe not as choppy as on the standalone...
This might indicate a bitrate overflow... I'm not sure... As the clipe is only 8 min I did not see the point in reducing the bitrate...
I used several different transitions in MM, but even 'fade to black' is choppy... The original AVI is smooth in VLC...
I dont mind the choppiness of the transitions as much as the lagging, as I can understand them...
Bugsy -
PS! I tried burning the DVD a second time using NERO at 2x speed (on 16x media), but the lagging is at the same place on both copies. So I don't think there is something wrong with the DVD-disc...
Appreciate your response! And I hope you ignore my spelling mistakes as english is not my native language...
Bugsy
PAL to NTSC and HCEnc
By ron spencer in forum Video ConversionReplies: 1Last Post: 30th May 2009, 15:03 -
Quenc Settings
By Maikeru-sama in forum Video ConversionReplies: 6Last Post: 14th Jun 2008, 20:57 -
Quenc Frontend
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 10th Jun 2008, 23:01 -
Quenc Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 16Last Post: 3rd Jun 2008, 11:36 -
CCE, Procoder, Quenc or HCEnc: which one do you get better results?
By devilcoelhodog in forum Video ConversionReplies: 28Last Post: 31st Jan 2008, 22:41
