ive got a few seris discs i want to back up but there to big for the disc you say the best way to do it for quality is to use dvd rebuilber and Cinema Craft Encoder Basic.cce is not free can i still use it to convert or duz it only convert so much as it is only a trail version.also ive been looking at the guides which tell u went straight over me had as any 1 got the latest screen shots of dvd rebuilber so i can set it up.and is Cinema Craft Encoder Basic worth buying.thanks andy and have a nicr christmas
Results 1 to 9 of 9
Is CCE Basic worth buying ? If you are generally going to use it only with DVD Rebuilder, and only occasionally, probably not. HCEnc can also be used with DVD Rebuilder, does a damn fine job, according to some, rivals and even betters CCE at low bitrates, and it is free. In fact, it ships as part of the DVD Rebuilder full install. If you want to spend a little cash, I would suggest you buy DVD Rebuilder Pro instead.
Read my blog here.
Personally, I find that Shrink (actually, any transcoder - this is not a Shrink specific issue) reduces the quality too much for such a large reduction. For episodic discs of that size I would either split them across two discs, and probably not need to reduce the size at all, or use DVD Rebuilder and encode at half-D1.
Read my blog here.
wot else do i need m8 and wot do u mean expand avsoptions wot do i selectOriginally Posted by guns1inger
All you need is DVD Rebuilder Pro. To expand a branch either click on the little + sign next to it, or double-click on it, just like any windows program.
Read my blog here.
8GB DVD into two dvds
By patelmiral in forum Authoring (DVD)Replies: 4Last Post: 8th Aug 2009, 17:23 -
getting a new pc...8GB DDR2 vs. 4GB DDR3...HP? Dell? Gateway? DECISIONS!
By burrowsfan in forum Newbie / General discussionsReplies: 3Last Post: 4th Apr 2009, 01:02
