I'm burning DVD+R's at 8X with multiple muxed mpg. files 22 minutes long using TDA 1.6. The muxed mpgs were first edited in VideoReDo Plus. The disc plays the first file/chapter fine but will not advance to the next chapter. The surface of the disc does not look like other DVD+R's I own. It has two seperate areas of burning, one heavier than the other. If I shorten the length of the files to 3-5 minutes each and burn the DVD it works perfectly.
I've tried the same procedures in Magix MEP 10 and it has exactly the same outcome.
I'm wondering what could be causing this and how I might fix it?
-Chris
Sounds like a burner issue. I don't know of any reason why it would burn various parts of the disc differently.
Google is your Friend -
Yeah that was it. Thanks! I swapped the old one out for a Sony DRU-720A and I'm burning DVD's that work.
AVI file length
By RonNYC in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2012, 17:47 -
Problem with DVD Architect: m2t file is being read only half the length
By eising in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2011, 03:30 -
Corrupt .mts file problem - length too short
By nlmts in forum Video ConversionReplies: 0Last Post: 2nd Aug 2010, 17:16 -
Strange problem - zero length files *only* after copying to DVD
By GregSchmidt in forum Authoring (DVD)Replies: 7Last Post: 28th Apr 2010, 11:05 -
file length problem
By danboy775 in forum Video ConversionReplies: 1Last Post: 30th Mar 2009, 08:21
