Asked this question before but have since forgotten the answer. Comparatively speaking, on TMPGEnc 2.521.58.169 under [Settings] -> Advanced -> Video Arrange Method: there is a pull-down that allows you to select one of the following:
Center
Center (keep aspect ratio)
Center (custom size)
Full Screen
Full Screen (keep aspect ratio)
Full Screen (keep aspect ratio 2)
No Margin (keep aspect ratio)
My question is: Where is this on TMPGEnc Xpress 3.0.4.24?????
Hey Mr. Taggert...ya want some beans?
The closest to that is in "Filters" - "Resize". The old style settings dialog seems to be missing that function. That can be located from the Set Output screen with the Advanced Settings - "MPEG Output" button.
Good luck. -
MPEG output here is just for modification of encoding template, not for resizing.
In Resize filter (it's uncheckable) there are 'full screen' and 'center' modes with an option to directly set the size in pixels in the final encoding. In full screen mode you have to uncheck 'keep AR' (on by default) unless your input is already resized for MPEG. -
Ah yes, thats where it is hidden. Thanks for the memory refresh...
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
