Hope someone can help me: In DVD-Lab i get no Audio on the main movie as soon as I add a slide show to the project. Without the slide show everything works fine. Looking at the final project there is a ac3 audio file on the DVD, but no sound. The sound in the slide show works fine.
Appreciate any assistance![]()
Thanks for replying. I am using ver 2.2. It's a single VTS project with different audio formats (probably where the problem is or?) The movie is a ac3 file demuxed from Premiere Elements and the slide show file is a .wav file. No audio on menu.
Different audio formats mean multi VTS authoring. DLP should have given you a warning at compile time.
The simplest solution ?
Encode everything to AC3 and drop a few seconds of AC3 audio on the menu. If you don't have an AC3 encoder, ffmpeggui is pretty good.
Because the spec says separate VTS's are required, most players will take the first audio as being the format for that titleset, and only play audio of that type. Usually this comes form the first menu, or the first title with audioRead my blog here.
Did you get a warning message when you went to compile your project?Originally Posted by rocka
Try putting them in different VTS's -- that should resolve the issue...
Regards,
George
EDIT -- ooops, I didn't see guns' post -- sorry -
OK, problem solved
Thank you so much for all help and quick response!
Edit: For your information DLP dit not give me a warning when compiling the project with the incorrect audio.
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 03:11 -
Audio Problem with VMG menu in DVD Lab Pro
By SCDVD in forum Authoring (DVD)Replies: 5Last Post: 22nd Apr 2008, 23:15 -
dvd-lab...no audio
By sylvester243 in forum Authoring (DVD)Replies: 2Last Post: 11th Jan 2008, 03:00 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
dvd lab pro audio error
By tomoftenville in forum Authoring (DVD)Replies: 7Last Post: 6th Dec 2007, 17:05
