Okay, I've got a standalone DVD recorder that can play .avi files. Thing is, the majority of divx/xvid files I d/l are in a extremely small letterbox ratio. If I encode a VCD etc myself, and set it to PAL 4:3 ratio, then everything's fine. But I don't want to have to wait a few hours just to encode a film that I will watch once, then wipe the CD-RW. So is there a QUICK way to change the .avi aspect ratio to make them play fullscreen on my standalone DVD recorder?
EDIT: I use TMPGEnc, so if that can change the aspect ratio quickly, then I'll use that, otherwise I don't mind using another program.
You can't go from WIDESCREEN to FULL SCREEN without cropping ... perhaps resizing ... then re-encoding.
Although WHY you would want to make WS to FS is a big ummm why? ... it makes no sense.
Aspect Ratio?: MKV -> XviD
By Randm in forum Newbie / General discussionsReplies: 9Last Post: 6th May 2009, 12:01 -
Aspect ratio for stand-alone DivX/XviD players?
By Gew in forum RestorationReplies: 1Last Post: 9th Mar 2009, 14:52 -
Converting VOBs to xVid with 4:3 aspect ratio?
By AOBCD8663 in forum Video ConversionReplies: 2Last Post: 18th May 2008, 21:31 -
Changing aspect ratio on an xvid encode
By SupaDawg in forum EditingReplies: 1Last Post: 6th Jan 2008, 04:59 -
Xvid to DVD with aspect ratio intact?
By StratPlaya in forum Video ConversionReplies: 12Last Post: 5th Jul 2007, 14:02
