When converting my captured Huffuyv files to VCD using TMPG it takes soo long, longer then usual AVI converts. Im guessing coz the AVIs are like HUGE. Anyway on speeding this up?
One of the main reasons a Huffyuv source takes a bit longer to encode is that it is optimised (speed wise) for compression rather than decompression.
My computer can compress to HUFFYUV faster than real-time but has a great deal of trouble trying to approach 10fps on playback. This primariliy is what is causing the delay, TMPGEnc must first uncompress the video and then compress again into MPEG.
Even so, when I re-encode I don't see the dramatic time increase which you mention in the post. Ensure that you don't have unnecessary filters turned on in TMPGEnc and switch the "Motion Search Estimate" from highest to high. (Most people here will tell you there is little difference between the two).
If the time really is an issue, you might like to try capturing to MJPEG (www.picvideo.com) with a quality setting of 19 or 20.
Does Converting MPEG1 2 MPEG 2 improve quality?
By purpleronnie in forum RestorationReplies: 10Last Post: 7th Aug 2009, 16:47 -
Problems converting from mp4 to mpeg1
By chukde in forum ffmpegX general discussionReplies: 2Last Post: 24th Feb 2009, 19:12 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
any tool for converting vob files to mpeg1?
By sumeshkri in forum DVD RippingReplies: 8Last Post: 18th Feb 2008, 23:22 -
converting from mpeg1 to divx
By mlkwestcoast in forum Video ConversionReplies: 3Last Post: 21st Dec 2007, 12:09
