Closed Thread
    Jul 2005
    Canada
    I was wondering if someone could help me I tried backing up a few movies with DVD FabDecrypter and then using DVDShrink but some would not work I still have these movies on hard drive is it possible to but them through FAB Decrypter from the hard drive as i dont have the DVDs anymore but the full movies are still on harddrive i used a older Fab decrypter but with a newer one i thought i would give it a go can some one explain how i can do this if possible thanks
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Basically, if you don't have the originals, your concern should be to get rid of the backups you've made.
    /Mats
