I am new to DVD writing. I have a NEC ND 3520A DVD RW.
On explorer when I open the directory tree, the drive for my dvd shows "DVD-RW Drive (D" On putting a DVD RW blank disk in it, autoplay gives me the option of burn disk and then the explorer shows "CD Drive (D
With a disk in the drive if I right click on the explorer, properties- general show that the disk is 0bytes used space, 0bytes free space and capacity as 0 bytes.
Properties - Hardware shows "_NEC DVD_RW ND-3520A" under All Disk Drives and DVD/CD ROM under type. Also device status shows it is working properly./
If I try to copy a file into queue, error message is "Windows encountered a problem trying to copy the file".
I have cleaned the drive but it just isn't working.
Please advise what I need to do?
What programs have you used to try to burn a DVD? Nero? Even if you don't have Nero on your system, you might download Nero Info Tool: http://www.cdspeed2000.com/ It may tell you a little more about your settings and hardware and may show any problems. For burning DVDs, also try the freeware ImgBurn.
Another possibility is that your drive is in PIO mode instead of DMA 2-4, but that usually just effects speed. Nero Info Tool should show that also.
Try some of these suggestions first. If it still doesn't work, then it could be a problem with Windows, or the cabling to the drive or a problem with the drive. I assume this is a drive in the computer, not an external one?
And welcome to our forums.
Would you still buy an NEC ND-3520A today?
By Number Six in forum DVD & Blu-ray WritersReplies: 13Last Post: 20th Mar 2008, 09:24 -
Problem writing on BD-R with a Lacie d2 Blu-ray burner
By L7dra7 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2008, 22:03 -
DVD writing speed problem
By dmckay2007 in forum Authoring (DVD)Replies: 3Last Post: 4th Dec 2007, 17:38 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 13:36 -
Problem writing to Philips dvd-r.
By jackrussell in forum MediaReplies: 0Last Post: 13th Jun 2007, 06:41
