Results 1 to 12 of 12
Thread: Playing DivX movies on my DVD player
  1. #1
    Member
    Dec 2006
    Canada
    Posts
    2
    I have a phillips DVD recorder with Divx capabilities....
    How do I burn the avi file to play on my dvd player?
    thanks!
    Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Posts
    11,301
    I think you have to burn as ISO+UDF but I use NERO EXPRESS for this (using the CD DATA DISC or DVD DATA DISC options) and it works without really telling you HOW it is burning but other people have said if you are using something else to do it as ISO+UDF or something like that.
    - John "FulciLives" Coleman
    Mod Neophyte redwudz's Avatar
    USA
    Posts
    24,327
    You also may want to make sure they are compatible with a Divx player. AVI ReComp can fix ones that won't properly play. Or several programs like avi.NET or AutoGK can encode to a compatible format.
    Member
    Dec 2006
    Canada
    Posts
    2
    Quote Originally Posted by FulciLives
    thanks for the replies guys! awesome site and awesome help!
    I will be using Nero 7 myself (I think it should have a DVD DATA option)
    So you are saying to just burn it using the DVD DATA option? Is there a subsection or just click DVD DATA and select the file?
    Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Posts
    30,239
    Just DVD data. Be aware - you cannot use multi-sessions discs in most players, so don't burn one movie now, then add another later. If you are planning on burning several movies to a disc, make sure you have them all and can burn them in one hit.
    Read my blog here.
    May 2003
    Posts
    11,301
    I have Nero 7 Ultra Edition myself and I just pick the Nero Express option which allows you to pick DATA CD or DATA DVD and that really is pretty much it.
    The only change I make is to set the recording speed to 6x because I don't like burning a DVD faster than that but that's just me perhaps. Different media on different burners ... to each his own when it comes to burning speed.
    I don't like Nero for DVD Video burning but for DVD Data or CD Data ... well it does that A-OK.
    Member
    Dec 2006
    Canada
    Posts
    4
    I guess this explains why my avi file does not play on my dvd player. I burned it as a video disk . Why would you burn it as a data disk? I guess I dont understand this at all.
    Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Posts
    13,177
    Video disk is VCD or SVCD or DVD. Those are mpg formats, so your AVI has to be converted and authored. Even if Nero claims to be able to do that, it's one of the worst solutions for it. We don't want that - we want your AVIs as files - which means a data disk.
    /Mats
    What model player?
    If we knew that we would know what to answer.
    Be sure to use short file names if you can with a philips.
    Member
    Dec 2006
    Canada
    Posts
    4
    Thanks, guys. I burned it as a data disk and it now works on my dvd player.
    My player is a DAENYX DV2001. It is DVDx certified and people on the net say it will play anything.
    Member
    Dec 2006
    Canada
    Posts
    14
    It is also one of the few Players that can play multisession recordings. For $29.99 from ToysRUs its a real good Player.
  1. Software and data files vs. playing movies - special dvd player?
    By Haopengyou in forum Media Center PC / MediaCenters
    Last Post: 18th Mar 2012, 06:55
  2. DVD Player capable of playing DivX Plus HD Content
    By werty12345 in forum DVD & Blu-ray Players
    Last Post: 11th Nov 2011, 21:11
  3. medial player stopped playing my movies
    By CheekyKid in forum Newbie / General discussions
    Last Post: 20th Jan 2010, 00:26
  4. Replies: 2
    Last Post: 13th May 2008, 01:18
  5. Help Playing divx from external HD through dvd player
    By Medward in forum DVD & Blu-ray Players
    Last Post: 19th Sep 2007, 14:14
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
