Its been 2 years since I had a pc and I used to use DVD Decrypter back then.
I see its been discontinued....is there an alternative someone can recommend?
For ripping DVD Decrypter can still be used in conjunction with ripit4me. I still use it for burning. But a lot of other people prefer imgburn, so you may want to check that out if all you're concerned about is burning.
This all free setup has not failed me yet...
RipIt4Me (Use the latest "Installer" file found on their website. It includes the latest FixVTS which is a required component)
DVD Decrypter 3.5.4.0
DVDShrink 3.2.0.15 with the "Burn with ImgBurn" modification
ImgBurn
RipIt4Me will automate the process of using DVD Decrypter, FixVTS, and DVDShrink to back-up a DVD. DVDShrink will then burn with ImgBurn. This setup will also automatically search for updates for each program and notify you if any are needed.
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 15:48 -
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 15:11 -
DVD Decrypter from one pc to another
By jwedge in forum ComputerReplies: 3Last Post: 27th Jan 2008, 00:35 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 17:55 -
Help with DVD Decrypter
By Me-Hostage in forum DVD RippingReplies: 10Last Post: 20th Aug 2007, 09:12
