In the gui4ffmpeg 2.1 files is a new ffmpeg included.
This makes some problems with the quality by encoding.
After some tests it is undependend from the compilation.
How to solve this issue:
You may play with two options:
qmin and qmax
The default in gui4ffmepg is:
-qmin 2
This is ok so far, but you have to add the option qmax.
qmax MUST be greater then qmin!
The quality will be worster by increasing qmax. In the
current ffmpeg the quality is without the option qmax
close to 30. This produces a very bad quality.
A good initial value is:
-qmax 5
If you have buffer underflows, you should increase the
value.
Anyway, some investigations are nessecary to find the reason
in ffmpeg.
The home of the sun - http://www.blueview.de.vu
I also noticed with newer versions of ffmpeg my bitrate, examle -b 6320, would show during convert as 6 kb/s (gui4ffmpeg v2.1). The outout mpg would end up being 300-1000k bitrate.
I now have to put a k at the end to show MB per-sec (-b 6320k), where on older version the k was not needed. -
thymej
Great hint!!!
To use gui4ffmpeg 2.1, please add a 'k' after the bitrate in the
related field in the GUI eg:
6000 -> 6000k
or
900 -> 900k
In the next version of gui4ffmpeg i'll put this automatically in the birate parameter.The home of the sun - http://www.blueview.de.vu
solved = struggling to get ffmpeg-php to compile
By richiedood in forum Video ConversionReplies: 30Last Post: 12th Jul 2011, 20:39 -
DVP-NS55P lockups -- SOLVED -- old ffmpeg produces corrupt AC3
By timmus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Nov 2008, 15:09 -
[SOLVED] 'fast action' with ffmpeg or Cinelerra?
By jdetwile in forum LinuxReplies: 2Last Post: 25th Mar 2008, 05:20 -
[solved] ffmpeg and iPod Nano V1.0.2
By Pixelartist in forum LinuxReplies: 6Last Post: 26th Nov 2007, 08:56 -
[solved] FFMPEG Mapping Question
By Pixelartist in forum LinuxReplies: 5Last Post: 13th Nov 2007, 07:02
