Hi
I have a Movie that the subtitles are green and blocky ant totally unreadable. is there anyway to edit this inf/vob files to correct the colour and font of the subtitles?
thanks in advance
Hoppy
Yes, the subtitle color information is in the IFO. It can be fixed with IfoEdit and I think there's even a special tool for this - take a look in the TOOLS section.
<edit>or even better - read on here!</edit>
/Mats -
thanks, i actually found the answer i needed
http://forum.doom9.org/showthread.php?s=&postid=283424#post283424
cheers
Hoppy -
The colors can also be fixed using DVDSubEdit, or, more easily in my opinion, in PGCEdit. Open the DVD in PGCEdit, double-click the movie, and change the colors to whatever you like for the outline and main color. If both the outline and main color are the same green, DVDSubEdit is probably the way to go, as you can make the changes and see the results on-the-fly, before making the changes permanent. Here's the guide:
http://download.videohelp.com/DVDSubEdit/Guides/ChangingColors/Guide.htm
Since DVD subtitles are image or picture based, you can't change the font without first performing an OCR, changing the font, and then converting back. -
Check tosee if your film has closed captions. I saw a film like this one you are mentioning & it has CCs instead.
unreadable greek subtitles
By ioakim in forum SubtitleReplies: 8Last Post: 12th Mar 2012, 08:45 -
By ioakim2an in forum SubtitleReplies: 1Last Post: 17th Aug 2010, 06:52 -
unreadable DVD becomes readable - why? how?
By JohnnyBob in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:11 -
Saving Unreadable DVD's Part Deux
By hitechluddite in forum Authoring (DVD)Replies: 21Last Post: 14th May 2009, 10:51 -
Can you make a dvdr unreadable?
By nuffskillz718 in forum Newbie / General discussionsReplies: 11Last Post: 27th May 2007, 05:13
