hi - i posted this at the adobe user to user forums and had no help, so i thought I'd try here. I'm currently running encore 1.5
I have a button highlighting issue - there are two buttons, on opposite sides of the menu with plenty of buttons in between. Anyway, i have checked many times and all the links are correct and the routing is correct.
The problem is that though it highlights the button on the far left when i navigate onto it, when i *click* on it, it highlights a button on the far right momentarily before it goes to the other menu the button links to. It still takes me to the correct video for the button on the far left, so this problem isn't a disaster if i can't fix it but it is a little annoying all the same.
I read on an older post on the other forums that this was due to a bug in encore dvd - any bright ideas or ways around it? They didn't have any solutions.
thanks for tkaing the time to read all this!
I expect that if it appears to be a known bug in the software, then the only fix would be updating/upgrading the software (assuming of course they have now fixed the bug).
Google is your Friend -
can't afford an upgrade, but thanks for replying anyway. it's not a huge probably, os i guess i can live with it.
Encore made DVD, playback issue
By Shtok in forum Authoring (DVD)Replies: 4Last Post: 12th Sep 2011, 13:49 -
NeroVision: DVD menu chapters highlight in wrong order
By Grunberg in forum Authoring (DVD)Replies: 0Last Post: 26th Apr 2011, 18:35 -
Highlight groups in Adobe Encore DVD 2.0
By prl in forum Authoring (DVD)Replies: 1Last Post: 10th Jan 2009, 12:54 -
Mux avi + audio, something wrong, an issue ? (solved by myself)
By sepulcrio in forum ffmpegX general discussionReplies: 2Last Post: 3rd Jan 2008, 11:11 -
Adobe Encore DVD black level wrong
By evoshandor in forum Video ConversionReplies: 14Last Post: 15th Oct 2007, 08:17
