Hello... new here and this is my first post. I've spent the last week creating movies from our old home movies from when we were kids as a Christmas present for my parents. I did all the editing in "imovie" and everything seemed to go alright. But when I put it into "idvd 5" to burn to a dvd no matter what I try the "burn" button remains greyed out and I cannot burn the movie to a dvd. I tried making an archive of the movie but still get the greyed out "burn" button.
I even went so far as to reinstall idvd and this did not help. I have a MacMini and this is the first time I've attempted to make a dvd. I have successfully burned regular music and data cds before on it but never tried a dvd. I hate to have wasted all this time making a movie that I have no way of getting off my computer so I can share it with my parents.
I hope someone can help, as I'm running out of time before Christmas!
Thank very much.
Kim
Did you try the "Save as disk image" item in the File menu? (I may not remember the exact wording.)
Yep I also tried that, but when it got to the end of the "rendering" process (think that's what it's called) I got a message saying "finished with errors" and it would not save the image even with "errors". Of course it didn't say what the errors were.
Kim -
Uh oh... boy do I feel silly. You're right... mine will only burn cd's not dvds. Helps if you read the manual!
Wonder if I can buy something to add to my mac so that I can burn dvds?
Thanks -
Regardless of whether your mini has a DVD burner or not, the version of iDVD you have (if it's the original that came with your mini) will "burn" to a disc image which Disk Utility will burn for you if you connect a FireWire DVD burner (about $100; $75 if you build one yourself).Originally Posted by dvkat
I have seen the error you mentioned in the "save as disc image" process and this usually is due to bad permissions so run Disk Utility and "Repair Disk Permissions" on your HD before you do anything else. Sometimes the iDVD project you've created has to deal with something "bad" you've put into your iMovie. You might try exporting from iMovie to a "full-quality" movie and then drop that exported movie into a fresh iDVD project.
You might also get ffmpegX and the Apple MPEG2 component (the latter from Apple); these will permit you to take the iMovie and author it to the requisite VIDEO_TS folder and image it. Disk Utility will then burn it. Toast is also a good option (and you won't then require Apple's MPEG2 component).
Burnz is also a great app for burning discs of many types but it has no ability to author a DVD (which Toast does have).
IDVD themes
By greeneyes21 in forum MacReplies: 3Last Post: 21st Jan 2010, 21:05 -
iDVD and subtitles
By Sgaar in forum MacReplies: 4Last Post: 4th Jan 2009, 23:37 -
No Audio in iDVD
By The Monkees in forum MacReplies: 8Last Post: 12th Feb 2008, 19:35 -
MPG's in iDVD
By The Monkees in forum MacReplies: 12Last Post: 10th Jan 2008, 18:56 -
No Sound in iDVD???
By TheMikesmith in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jun 2007, 12:48
