    Dec 2006
    Australia
    hi there! What is the best software to burn copyprotected dvds? thanks
    Apr 2004
    Miskatonic U
    You can't burn copy protected DVDs. You need to break the protection before you can copy the contents. After than, pretty much any good quality burner will do the job. I like NEC burners, Pioneer have a great reputation, and many seem to swear by lite-on drives.
    Read my blog here.
    USA
    I don't think you will find a way to burn a copy protected DVD. At least not directly as you will have to decrypt it first. If you decrypt it, then any burner should work. I'm assuming a commercial pressed DVD.
    If, though, you are asking how to back up one of your own discs, then some of us use RipIt4Me for the newer DVD encryptions. Then DVD Shrink and burn with ImgBurn. All freeware and they work very well together.
    You can skip RipIt4Me for older DVDs and just use Shrink and ImgBurn. There is also a modified version of DVD Shrink that uses ImgBurn automatically to burn the 'Shrink' DVD. You can find it here: http://forum.digital-digest.com/showthread.php?t=63869
    Or, if you want to burn a decrypted DVD without shrinking to a DL disc, DVD Decrypter is one simple way: ISO Read>ISO write. Very easy.
    If you are just asking about what is the best burner in general, You will get lots of opinions. I myself like the Pioneer 111, but that's my opinion.
  4. Member steptoe's Avatar
    Try looking at SlySoft for AnyDVD that will remove copy protection and also audio CD copy protection
    It will w ork with virtually any DVD ripping software
    Have a look at their own DVD copying software, CloneDVD
    Also, a lot of people seem to like using DVDFab Platinum as it rips and burns in one piece of software
    MY personal choice is to rip it using AnyDVD with DVD Decrypter and DVD-RB Pro to get the best quality from the final result
