does today hi-end Video Card will help me while:
editing HD video
authoring/encoding HD
sorry!!!
Venereal Disease?
Video card does not matter. You need cpu, memory, storage space...in that order.
Google is your Friend -
They do make video editing cards specifiaclly for that.
http://matrox.com/video/home.cfm -
Explain more what you are trying to do and your budget. What camcorder are you using? What other HD source? There are several ways to edit and encode HD.Originally Posted by chris_j11
But the video card typically only helps with decode for display. That is beginning to change.
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 16:42 -
Software Encoding on High-End System
By tbradyjd in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2010, 22:36 -
will a separate video card speed up video encoding?
By edong in forum ComputerReplies: 12Last Post: 21st Oct 2009, 18:37 -
Finding A High End Graphics Card For Laptop
By Nitro89 in forum ComputerReplies: 10Last Post: 24th Oct 2008, 23:31 -
Low End Video Card w/ adapter vs. Low End DVD player
By enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 16:45
