I have burned programs using a bin & cue, but the movie scene is new to me.
Is this done in the same manner?
I used WinImage to see what was in the bin and I saw files and folders just like on a program disk. Does this turn into a movie somehow? If so if burned with a cd-rw will it play and do you need to have special software?
Like I said I am new and willing to learn.
TIA
Buring a (S)VCD is the same as burning a program. Just avoid using CDRWIN 4.0 Beta, it doesn't burn the bin/cue image correctly.
All those file and folder you see is required for a stand alone player to figure out what kind of movie you're trying to burn, i.e. VCD or SVCD.
CDRW will work only if your stand alone player accept that format. If you're playing it on the PC, then you need a movie player like MS Media player or VCDcutter, etc.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
