Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Dec 2006
    Hi, I have been using Nero Recode to convert files to mp4s so that I can play them on my iPod. The past few days however the audio is faster than the video by say 5 sec. There seems to be no problem when I use Videora, however Videora ipod converter is not as fast as Nero Recode and so does anyone know what the problem could be? Thanks
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    What format are you converting them from? Sync problems can be caused by the audio format, at times VBR audio. You can probably check the original file with Gspot 2.60. If you can find one that encodes without problems and one that doesn't, you should be able to figure out the difference and there may be an adjustment you can make.
    And welcome to our forums.
    Dec 2006
    Thanks for the warm welcome.
    I am converting from AVI and when I opened it up with Gspot there seemed to be no problems. Do you thing changing the audio's bitrate will help?
  4. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    Probably not audio bitrate. Sorry, I'm just guessing as I don't use Recode. If you see nothing different between the videos that work and the ones that don't, then it comes back to Nero.
    Maybe something changed with the program. About all I can suggest is that a program that may have been added is doing something with Nero. The other thought is to uninstall Nero and reinstall it. I would use the Nero Clean Tool for that as it seems to be able to remove Nero remnants better.
    If you knew exactly when the problem started, you might be able to pin it down better. You might try a Windows restore to a time before the problem. But back up important files before you try this.
    And visit the Nero site, if you haven't, to see if this is a problem others have ran into.
    Or one of our members that use Recode may have some better ideas.
    Dec 2006
    Is this an avi using the divx codec? Was this converted with a VBR for the audio? If so, as already suggested try converting audio to a constant bit rate and not variable (for both original program and recode). I've use recode many times (admittedly not with portable settings) and never had a synch problem - unlike other programs!
    Dec 2006
    I am gonna try reinstalling Nero. Hopefully that works.
    Also the out of sync issue seems to only happen when I encode 20-30 min shows because when I encode say 1 1/2 hour movies there are no problems, everything is in sync.
  7. Banned
    Jan 2007
    i had the same issues with my audio and video being out of sync with videora, but this tutorial fixes it:
    http://ipodlegends.com/videora-audio-sync-fix/
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Baldrick
  8. Member GMaq's Avatar
    Mar 2004
    Canada
    Hi,
    The only time I've ever had sync problems with Nero is when I've used the video trimmer to set the beginning and end points on the file to be encoded. Now I trim/edit with other apps before going to Nero and haven't had any further Sync issues.
