Okay anyone using Easy RealMedia Prodcer... For me this is the best RMVB converter ever made... it preserves the AVIs quality at max compared to many other proggies and it is easy to use... it also nearly converts all existing formats to RMVB if the right codecs are installed.
What i want to do is convert MKV/OGM to RMVB... What the proggie does is convert it to RMVB using the default language(sound) but won't add the subtitles. I only work with anime and prefer japanese audio over english audio. I am sure that the program allows adding external subs during conversion since the program comes with vobsub and also works with avisynth.
It would really save me time if u could help me on this as i wouldn't have to convert the dual audio to avi first.
Can someone make a small tutorial of adding hardsubs using this program...like telling which options are to be clicked etc... and if a command line is to be used can it be given as well as the variations if i have to edit. I am totally noob to command lines
Thank you in advance.
anybody able to help me for this?
should i post the same thread in another forum section?
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 02:20 -
Adding subs.
By Ytrix in forum SubtitleReplies: 2Last Post: 21st Oct 2010, 11:39 -
Adding external hard drive
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 14th May 2008, 02:07 -
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2008, 22:05 -
Adding Subs
By Russo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2007, 20:45
