Hi,
I have a problem here and was wondering if anyone could help.
Basically i uninstalled ffdshow codec, and realised later that all my other codecs (default - microsoft etc /undefault) are no longer being detected. I'm not sure if they are still installed or are already lost in the process.
But even after reinstalling ffdshow, my codecs list only shows ffdshow.
And for online streaming videos like youtube etc... there is no audio.
I can only play offline videos properly.
So may i know what's the problem, and if there's any way i can get back all my default windows codec?
Thanks.
You can use codecsniper to browse and cleanup your existing codecs.
You could reinstall the wmv codec package from microsoft. As for any other codecs, just reinstall what is needed when you have a use for it.Google is your Friend -
A while ago, I had a similar problem with codecs that stopped working. Filmerit (http://paul.glagla.free.fr/filmerit_en.htm) was able to repair them all in one shot. A little confusing to use but it did the job.
When uninstall FFdshow-20060803-rev2546 (drevil_xxl compilation)... delete a keyOriginally Posted by vidvid
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32]
from system registry.
Create .reg file and import to registry:
+ Reinstall undefault codecs (Xvid, ...).Windows Registry Editor Version 5.00
"midimapper"="midimap.dll"
"msacm.imaadpcm"="imaadp32.acm"
"msacm.msadpcm"="msadp32.acm"
"msacm.msg711"="msg711.acm"
"msacm.msgsm610"="msgsm32.acm"
"msacm.trspch"="tssoft32.acm"
"vidc.cvid"="iccvid.dll"
"vidc.I420"="msh263.drv"
"vidc.iv31"="ir32_32.dll"
"vidc.iv32"="ir32_32.dll"
"vidc.iv41"="ir41_32.ax"
"vidc.iyuv"="iyuv_32.dll"
"vidc.mrle"="msrle32.dll"
"vidc.msvc"="msvidc32.dll"
"vidc.uyvy"="msyuv.dll"
"vidc.yuy2"="msyuv.dll"
"vidc.yvu9"="tsbyuv.dll"
"vidc.yvyu"="msyuv.dll"
"wavemapper"="msacm32.drv"
"wave"="wdmaud.drv"
"midi"="wdmaud.drv"
"mixer"="wdmaud.drv"
"aux"="wdmaud.drv"
"msacm.msg723"="msg723.acm"
"vidc.M263"="msh263.drv"
"vidc.M261"="msh261.drv"
"msacm.msaudio1"="msaud32.acm"
"msacm.sl_anet"="sl_anet.acm"
"msacm.iac2"="iac25_32.ax"
"vidc.iv50"="ir50_32.dll"
"msacm.l3acm"="l3codeca.acm"
No sound on MPEG-2 files in WMP11 after uninstalling 3rd party codecs
By brassplyer in forum Software PlayingReplies: 1Last Post: 12th Jan 2012, 04:15 -
looking to find out the standard in video codecs that are used by default
By rickywh in forum Newbie / General discussionsReplies: 4Last Post: 12th Apr 2011, 11:58 -
FFDShow + Official Codecs - can they coexist?
By Foxhack in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2010, 15:33 -
Installing ffdshow to solve codecs problem?
By giunghi in forum Newbie / General discussionsReplies: 11Last Post: 22nd May 2009, 06:42 -
make ffdshow default
By mrcoolekin in forum Software PlayingReplies: 4Last Post: 26th Nov 2007, 05:54
