Hello everybody!!
I'm trying to convert some FLV taken from youtube to AVI. Some of them work pretty good, but others encode the video at high speed, and audio at normal speed. The result is a shorter clip (it stops encoding when reaches the end of video, and being video at a higher speed, it finishes before it should). I don't know if it has something to do with the lenght of the source file, after a few attempts I've been doing with several files (some worked, some others didn't), it seems that long files (more than 5') fail more than short ones. Does it make any sense to anyone?
Thanks for your help!!
PS: On my previous post (https://forum.videohelp.com/viewtopic.php?t=316847), it seems that when the original size is 320x239 instead of standard 320x240, encoding finishes immediately and resulting fil is Zero KB. Thanks for the help with that one, by the way!! Does anyone know how to change the size of a FLV source clip, is there a software for that (and Mac friendly also )
