Good Morning,
I don't know whether the terminology of "Batch Frame/Image cropping" is correct or not so I'll explain what I would like to do. I will be creating an avi file extracted from a Google Earth tour. I will be including this segment in a Christmas video. I would like to only use the middle 70% of the frame as I don't want the Google Earth logos and Lat/Lon updates to appear in it. Is there any avi / video editors that can accomplish this?
Cheers,
Dave
For avi ... vdub ... video > filters > resize .
Back in previous box , you'll be given the option "crop" ... it'll be available now .
Go here , and set the cut off's as required .
It's a funny thing to use ... esspecially setting the resize to take into account the cutoff's so as not to distort the clip and keep original size ... without adding too much picture degradation in quality .
For mpeg / vob ... virtualmod , same process . -
Personal choice, but I would add the Null Transform filter first, and do the cropping required. I would then exist the filter dialog (click OK), then come back in and add the Resize filter. Slightly different approach to achieve the same outcome.
Read my blog here.
Thank you both for your input and quick replies!!! This app does exactly what I need it to do. Will be sure to post my finished vid here next week.
Dave
Frame by frame cropping?
By bodybobo in forum EditingReplies: 2Last Post: 12th Jun 2010, 04:53 -
How can I cut out an image from a mpg file? Just one frame
By szalaikornel in forum Video ConversionReplies: 4Last Post: 28th Jan 2009, 10:59 -
batch WMV to AVI that will maintain video bitrate and frame dimensions
By chief1972 in forum Video ConversionReplies: 2Last Post: 27th Dec 2008, 13:17
