Recently I bought a VGA converter manufactured by AV TECH from Taiwan, and I think this product is quite good after using for a week. The price is cheap and lower than other VGA converters, but it's quality is much better than I expected. The image output on my LCD monitor is very sharp and clear, and the installation is very easy. No additional driver program is needed. In addition, it can also work with other image output devices, such as DVD Player, DV recorder...etc. The connection line can be extended up to 50m if needed. (I've done the testing and the image is still very clear within 40m without any distortion!)
Below is the information for this VGA converter. If you have any interests, you can take a look![]()
http://www.avtech.com.tw/english/product_5_vga02.htm
Results 1 to 1 of 1
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
PC VGA to VGA on LG 42" Plasma
By Squirralien in forum Media Center PC / MediaCentersReplies: 3Last Post: 8th Nov 2008, 21:43 -
laptop with only VGA to VGA-less HDTV
By liiam in forum DVB / IPTVReplies: 0Last Post: 16th Oct 2008, 15:16 -
SVGA and VGA?
By warlock110 in forum ComputerReplies: 1Last Post: 11th May 2007, 20:07
