But nothing of that in Capture Mode, right? Because I've only ever changed this stuff in Capture Mode.
For example, I have never changed this "Audio/Video Interleaving"... could that be the reason for the audio sync problem?
And by MPEG, I mean FFMPEG in the Compression list.
Results 151 to 154 of 154
Install this fast codec and retry your capture
https://forum.videohelp.com/threads/401614-VHS-to-DVD-and-MRL-files#post2618026
If it's still out of sync, install Amarectv as mentioned in that same post -
Hello again! I've finally found the time to test out AmRecTV and it actually almost works too well. So thank you for that!
There's only one issue: After some minutes of recording, both VHS tapes I've tried so far begin to stutter, with a lot of lost frames.
I rewound the tapes to see if it was their fault, but the second time, the same part played normally.
Any ideas what could cause the stuttering? Maybe the file size? Even just three minutes are 1GB and my computer isn't exactly state of the art.
I'm using the codec you advised me to try and of course have the settings set to NTSC_M_J. The VHS tapes in question are all NTSC 3.58. -
Hello,
I have such problem, that I have video and I need to record speaach to it. The speach is faster then the video so it is not synchronized. I would like to use some FREE program to insert delays manually and then use video cutting tool. I use windows XP where I use avidemux 2.5.6 and virtualdub. But I think that it is not possible to insert the audio delay to it, be it simple. So you know some program which can run on Win XP for free to be able to do that?
Audio/video Out of Synch in Converted AVI File
By Novice20 in forum Video ConversionReplies: 1Last Post: 31st Aug 2011, 03:10 -
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 10:46 -
How to fix the lagging audio of a converted AVI file?
By PunkMaister in forum Video ConversionReplies: 15Last Post: 17th Feb 2009, 19:38 -
Audio synch problems on an .avi file -noob
By ComicFan2 in forum ffmpegX general discussionReplies: 4Last Post: 18th Dec 2008, 13:47 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 19:00
