I'm new to encoding Divx files and need some help. I need to encode several different file sizes so that they fill an entire 4:3 television screen.
384x284 and
576x432
When I tried to play the 384x284 sized file, it showed up on the tv screen as a small square in the center of the screen. What size, or other things, do I have to make the file to make it fill the entire tv screen ? 16:9 (640x368....or about that) files seem to play just fine and take up the full width of the television screen. If it helps, I use ffmpegX 0.0.9u. Thanks.
Results 1 to 1 of 1
Think about this. Once bread becomes toast, you can't make it back into bread.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
