Hello,
I have a .swf flash file that I am trying to convert to .mp4 so that I can use it on my iPod.
I am using ffmpegX 0.0.9x and my MacBook Pro. When I open the .swf with ffmpegX the "Source format" pane says the format is "unrecognized." If I try to transcode the video anyway it finishes in less than a second and gives me this "Process Information" when I click on the "i" in the blue circle:
I don't understand why ffmpegX can encode to flash but not from flash. Can anyone help me?FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Sun Dec 17 15:05:30 EST 2006
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[swf @ 0x5597b8]No media found in SWF
/Users/chadly/Desktop/I Work at Burger King.swf: I/O error occured
Usually that means that input file is truncated and/or corrupted.
thanks, c
I bet it said 'Unrecognized/No video/No audio' in the Summary window.Originally Posted by chadstone30
ffmpegX can encode to FLV, while not every SWF file contains (FLV) video. Your clip likely wasn't really video, but a background picture with a scripted quasi moving mouth.Originally Posted by chadstone30
You could try to capture it as real video with a tool like Snapz Pro X.
dude, you're exactly right. what i ended up doing was using a program called WinAVI that converted it perfectly. thanks anyway though. c
scr to swf or avi or mpg
By faithcopeland in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2008, 02:05 -
SWF mx, swf 3 ( legacy ), and FLV, whats the difference
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2008, 00:15 -
avi to swf or mov to swf
By halteach in forum ffmpegX general discussionReplies: 2Last Post: 2nd Dec 2007, 07:18 -
Need an expert advise on converting AVI (or SWF) to MPG High quality video
By oavs in forum Video ConversionReplies: 10Last Post: 10th Jul 2007, 15:41 -
MP4 video to avi or mpg
By mysts in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2007, 13:59
