Can I mount VOB/ISO files with Daemon like I mount ISOs? Is there any way to do this other than burn an ISO with Nero, then mount?
Results 1 to 12 of 12
Daemon Tools is for image files. You can use Imgburn to create an ISO then mount that using Daemon Tools.
He's a liar and a murderer, and I say that with all due respect. -
Nope, you can't mount vob files. You can use the command line tool subst to make a virtual drive from a video_ts folder...but it wont be exact same as a virtual dvd. But why do you need it?
"why do you need it? "
I've got programs that will read a DVD and will read an image mounted, and will read an unmounted image, but won't read decrypted VOB/ISO files. Occasionally that's what I have when I need to use a program that won't read them. -
Read my blog here.
Steveryan is the only poster that has given you any decent advice. YES, if your dvd is ripped to ISO, you MOST DEFINITELY can mount it to a virtual drive using daemon tools. After mounting, view it in whatever your favorite software dvd player is.
What do you mean by "VOB/ISO files?Originally Posted by MrFoxer
An ISO containing VOBs? -
1) I don't have any encrypted files on the HD, just decrypted or original non-encrypted.Originally Posted by MistaED
2) I know I can mount ISOs, I want to mount VOB/IFOs without first making an ISO
3) Sorry about the typo of "VOB/ISO" I meant VOB/IFO/BUP as in a ripped DVD nonencrypted structure file set
I'm aware that I can make a ripped VIDEO_TS subdir look like a drive w/ a drive letter I assign, but it does not appear as a DVD drive the way a mounted ISO does, so other programs that are looking for a DVD disk don't see it. Sooo, I'm still looking for an easy way to make VOB/IFO/BUP files look like a mounted DVD disk. Is it impossible (other than burn to an ISO and mount that)? -
If you can spare 5 GB you can make a partition on a hard disk and if you copy the VIDEO_TS etc folders and files there it might work.
Short answer : you cannot mount VOB/Ifo files in the same way you can mount an ISO file. An ISO file is a disc image, and can be made to act like a dsic. VOB/IFO files are just files. If your player will only play from DVD discs (or mounted images) then you will either have to write to an RW or create an ISO.
Read my blog here.
Buying a monitor mount
By A Traveller in forum ComputerReplies: 6Last Post: 23rd Dec 2016, 00:26 -
Can you mount an .ISO image to a hard drive , then copy the VIDEO_TS folder
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2011, 19:11 -
lcd wall mount help.
By nick101181 in forum Off topicReplies: 2Last Post: 13th Dec 2009, 09:20 -
Help me! I can't play file *.mds file after i 'mount image' using daemon
By i_nui in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 14:04 -
Camera Mount Instructions for a Bicycle
By Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jun 2007, 16:42
